[GRASS-user] LRS and Documentation
Luca Casagrande luca.casagrande at gmail.com
Thu Dec 6 13:32:20 EST 2007
Hi Markus and thanks for your answer.
With v.net i have created a new node file for my network ( to be sure
that node are connected to network).
Using that one as "milestone" I have 5 lines that go in the right output
and 11 that go in the error one with the same warning then before.
Bye
Luca
Markus Neteler ha scritto:
> Hi Luca,
> maybe you need to run v.net on the network first, see
> its man page for instructions to add missing nodes.
> Markus
> On Thu, Dec 06, 2007 at 06:39:56PM +0100, Luca Casagrande wrote:
>> Hello everybody,
>> i am doing the tutorial from:
>> http://grass.itc.it/grass63/manuals/html63_user/v.lrs.create.html
>> and all seem fine, until I run the last command (v.lrs.create).
>> v.lrs.create --o busroute points=busstops out=route_lrs err=lrs_error
>> lidcol=lid pidcol=lid rstable=route_lrs thresh=50
>> This is the error:
>> WARNING: Not enough points (0) attached to the line (cat 1), line skip.
>> WARNING: Not enough points (0) attached to the line (cat 16), line skip.
>> After that out_lines is empty and lrs_error show the whole network.
>> Am I missing something?
>> Thank you
>> Luca
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
