[GRASS-user] nan values by v.generalize
Hamish hamish_b at yahoo.com
Sun Dec 16 15:01:35 EST 2007
Daniel Bundala wrote:
> As I mentioned in my previous post, a solution is to translate the
> corresponding points little bit.
be careful that moving a vertex a little bit in a location where the
units is meters might seem harmless but the same change in a lat/lon
location could be damaging. the location's projection units could just
as well be km, lightyears, ... too.
I would think it better to do the operation in 2 passes if some
cleaning is needed, and only fudge the data as a last resort.
maybe the v.clean remove small angles tool helps here.
2c,
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
