[GRASS-user] Trying to export a 3d Layer
Matthew Pulis mpulis at gmail.com
Fri Dec 21 14:09:38 EST 2007
I am trying to export a contour layer to PostGIS / Shapefile / GML but to no
avail. The files I am trying to export are in GRASS Vector format, thus I am
using v.out.ogr. I am using the dataset found with the Grass Book Edition 3
(North Carolina). My layer is elev_contour_3m. I tried also to load the 10m
contour layer in the same dataset but got the same results, so I do not
think it is a problem of the vector files, but more of an exporting problem.
Any help how I can make this layer into a useable layer outside GRASS is
extremely appreciated!
I am taking this email to wish everyone on the list best wishes for
Christmas and New Year to you and your families :)
Matthew
I am supplying some info which might help you give me some tips how I can do
it.
GRASS 6.3.0RC1 (thesis):~/thesis_gis/thesis/yancho/vector/elev_contour_3m >
v.out.ascii elev_contour_3m format=standard | head -n 20
ORGANIZATION: NC OneMap
DIGIT DATE:
DIGIT NAME:   helena
MAP NAME:
MAP DATE:     Fri Mar  9 12:12:48 2007
MAP SCALE:    1
OTHER INFO:
ZONE:         0
MAP THRESH:   0.000000
VERTI:
L  309 1
 644845.39132067 228495       58
 644850.5257363 228485       58
 644855       228476.80568172 58
v.db.select elev_contour_3m
DBMI-DBF driver error:
Table 'elev_contour_3m' doesn't exist.
Error in db_open_select_cursor()
v.info elev_contour_3m
 | Layer:           elev_contour_3m
 | Mapset:          yancho
 | Database:        /home/yancho/thesis_gis
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: helena
 | Organization:    NC OneMap
 | Source date:     Fri Mar  9 12:12:48 2007
|   Number of lines:        3355            Number of islands:    0
And these are the output formats I tried :
v.out.ogr input=elev_contour_3m format=ESRI_Shapefile
dsn=/home/yancho/elevation.shp
WARNING: Vector map <elev_contour_3m> is 3D. Use format specific layer
         creation options (parameter 'lco') to export in 3D rather than 2D
         (default)
ERROR: Unable to describe table <elev_contour_3m>
v.out.ogr in=elev_contour_3m type=face dsn="PG:host=localhost dbname=thesis
user=usernamehere password=passhere" format=PostgreSQL lco="SHPT=ARCZ"
         (default)
I tried also lco="DIM=3" but got same results.
  _____
I am using the free version of SPAMfighter for private users.
It has removed 18742 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter <http://www.spamfighter.com/len>  for free now!
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071221/5e7d2527/attachment.html
