[GRASS-user] Building gdal for use with grass and MrSid
cdavilam at jemila.jazztel.es cdavilam at jemila.jazztel.es
Sun Dec 23 07:53:26 EST 2007
   Rainer M Krug <Rainer.grass en krugs.de> ha escrito:
> Hi
> I have to compile gdal from source as I need MrSid support (I have a
> huge number of MrSid files and I don't have enough HDD space to convert
> them to geotiff...). Therefore I have to compile gdal myself. As I want
> to have the same functuonality of GRASS 6 with gdal, I am wondering:
> which options should I set to get a gdal with all the "standard"
> functuanality as in the SuSE 10.2 package.
> I would compile gdal 1.4.4 with MrSid support from source and use
> checkinstall to create the rpm which I would then install.
> In addition: I have four rpms with gdal installed, namely
> libgdal0-1.4.2-2.1
> libgdal-devel-1.4.2-2.1
> libgdal-grass-1.4.1-1.7
> gdal-1.4.2-2.1
> would any of the libgdal packages affected when I install gdal from
> source? If yes, how can I compile and install them?
   I have created deb packages for gdal in a couple of ocasions, for a
similar reason (get ecw support). When you finish packaging, you get
all gdal packages for the version you are compiling, except
libgdal-grass, which normally is compatible with the others.
   I hope this help.
   Regards,
   Carlos
> Thanks,
> Rainer
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user[1]
Vínculos:
[1] http://lists.osgeo.org/mailman/listinfo/grass-user
2007 Jazztel - Jazz Telecom, S.A.U.         http://www.jazztel.com
Antes de imprimir este e-mail piense bien si es necesario hacerlo.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071223/3d6979b5/attachment.html
