[GRASS-user] Re: importing shapefiles - segfault
Maris Nartiss maris.gis at gmail.com
Fri Feb 9 02:39:47 EST 2007
Hi Tyler,
first - You should upgrade to GRASS-6.2.1, as there are lots of
bugfixes in all areas.
Second - when You ask for help, You should mention Your platform,
where You get GRASS (package, selfcompile). Also GDAL/OGR version
would be good, if You have problems with import/export via GDAL/OGR.
WBR,
Maris.
2007/2/9, Tyler Smith <tyler.smith at mail.mcgill.ca>:
> Hi,
> I'm trying to import some ESRI shapefiles, but I can't get it to work
> properly.
> This is what I did:
> GRASS 6.0.2 (ESRI_World):~ > v.in.ogr dsn=/home/tyler/esri_data/usa/
> output=ESRI_states layer=states min_area=0.0001 snap=-1
> location=ESRI_USA3
> A datum name nad83 (North_American_Datum_1983) was specified without
> transformation parameters.
> Now select Datum Transformation Parameters
> <snip>
> 6       Used in Default nad83 region
>         (PROJ.4 Params towgs84=0.000,0.000,0.000)
>         Default 3-Parameter Transformation
> Enter 'list' to see the list of available Parameter sets
> Enter the corresponding number, or <RETURN> to cancel request
> >6
> Layer: states
> WARNING: Default driver / database set to:
>          driver: dbf
>          database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> Segmentation fault
> I used the same command to setup a new location with ESRI world data.
> The .prj file for the USA data is:
> GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",
> SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],
> UNIT["Degree",0.0174532925199433]]
> I tried some googling, but couldn't make sense of the results. I've
> been using the data in ARCView without problem, and just copied the
> entire data directory from a Windows box to a GNU/linux box, so I
> think all the relevant files are there.
> Thanks for any suggestions!
> Regards,
> Tyler Smith
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
