[GRASS-user] edit vector map comments
Daniel Farnan DanielF at SHARECHIVE.com
Fri Feb 9 19:03:16 EST 2007
Meta Data - if this is where it resides, for files, it should be more
distinct and easier to access (ie maybe even auto-generate a file with GRASS
version and appropriate Kudos to developers). (ie, USGS vector Data,
GoogleMaps Raster or...)
I believe URISA has a Meta Data Standards (perhaps for a text box, or
terminal Q/A) and there is the GISCI Meta Data Standards - I think.
(http://www.gisci.org/)
(http://www.urisa.org/)
-----Original Message-----
[mailto:grassuser-bounces at grass.itc.it]On Behalf Of Markus Neteler
Sent: Friday, February 09, 2007 3:38 PM
To: grassuser at grass.itc.it
Subject: Re: [GRASS-user] edit vector map comments
On Fri, Feb 09, 2007 at 09:34:51AM -0500, Wouter wrote:
> Hi list,
> what's the easiest way to edit the comments section of vector map (the
> field that shows up with v.info)?
I am also interested... I fear that we need a new command
for this to edit the "head" file of a vector map.
Markus
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
