[GRASS-user] Different coordinate system maps
Hamish
hamish_nospam at yahoo.com
Tue Feb 13 03:22:53 EST 2007
Carlos Dávila wrote:
> I would like to know if is there any way to load into a workspace maps
> that are in a different coordinate system than the mapset you are
> working in. In my case, I have a location using UTM zone 29 and I need
> to display some maps georefered in UTM zone 30. Is there any
> possibility?
Use r.proj and v.proj to pull in maps from another location with
different projection settings.
Be aware that the further you go out into the bordering UTM zones, the
more distortion you'll see.
Hamish
