[GRASS-user] d.m.tcl
Mon Feb 19 00:24:57 EST 2007
Maciej Sieczka wrote:
> The reason for d.m not starting is a recent change introduced to
> ps.map, which d.m calls at startup. After this issue is solved, d.m
> will be operational again. Developers are informed:
> http://grass.itc.it/pipermail/grass5/2007-February/029067.html
> Note that this problem has been reported in another email too:
> http://grass.itc.it/pipermail/grassuser/2007-February/038483.html
fixed in CVS.
> Michael Barton wrote:
> > "d.m" is a script that calls the old x11 display based TclTk GUI. It
> > is no longer supported, though it still ships with the default GRASS
> > build for backward compatibility and because some people prefer it.
I will continue support d.m (keep it going; attempt to fix bugs) until
the new WxPython GUI comes online. I plan on removing d.m from the
Makefile the same time the wxGUI is added. There will be no new d.m
development, gis.m is currently the active target.
Hamish
