[GRASS-user] GRASS 6.2.1-1 Installation Question
Mon Feb 19 17:33:04 EST 2007
Ramu Narayanan wrote:
> d.mon x0
> The following message appears:
> GRASS 6.2.1 (spearfish60):~ > d.mon x0
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting x0. Will try once more
> GRASS 6.2.1 (spearfish60):~ > d.rast soils
> No graphics monitor has been selected for output.
> Please run "d.mon" to select a graphics monitor.
> I get similar messages regardless of whether I do this in the GRASS
> command prompt or the Grass Manager window.
> The list and info commands appear to be working.
does the same happen after quiting Cygwin and restarting?
what about,
 d.mon start=x1
 d.mon select=x1
(up to x6, "d.mon x0" is a shortcut to the above two commands)
Hamish
