[GRASS-user] import E00 files in GRASS under Cygwin
Stephan Holl stephan.holl at intevation.de
Thu Jan 4 09:33:48 EST 2007
Hello Stefaan,
"Stefaan Vande Walle" <Stefaan.VandeWalle at sadl.kuleuven.be> wrote at
Thu, 4 Jan 2007 14:45:14 +0100:
> Dear,
> I use GRASS 6.1 under Cygwin and I want to import E00 files in
> GRASS.
> v.in.e00 calls for avcimport.  I suppose the gz. File is to be used
> (or is it also possible with the Win32 files) ?  But where is it to be
> installed and how can it be activated?  Does a C-compiler needs to  be
> installed for this?
I am afraid you need to compile from sources for cygwin. Perhaps
someone has some experiences compiling avcimport on cygwin?
Good luck.
	Stephan
Stephan Holl   : www.intevation.de/~stephan | GISpatcher:
www.gispatcher.de Intevation GmbH: www.intevation.de          | GAV
e.V.: www.grass-verein.de Georgstr.4     : 49074 Osnabrück            |
Telefon  :  +49(0)541.3350832
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070104/fd29752c/signature.bin
