[GRASS-user] problem with vi.in.ogr
Jarek Jasiewicz jarekj at amu.edu.pl
Sat Jan 6 16:47:54 EST 2007
> What GDAL and PROJ4 version?
gdal 1.4.0 RC1 (fresh) Proj4 4.5 (fresh)
fresh means not upgraded, installed on fresh system
> Please send "g.proj -p" of your target GRASS location and the "ogrinfo
> -al -so" of your input shapefile.
Nothing interesitng, I checked it before. I wrote so I erlier imported lot of
files from ArcView to THAT grass location without problems. I suspect file is
corrupted, but I cannot find reason: In ArcView I opened it without problems
(I have "." as a separator) in qgis (latest 0.8) also opens without problems
ogrinfo:
INFO: Open of `/home/jarekj/shp/PunktyAZP.shp'
      using driver `ESRI Shapefile' successful.
Layer name: PunktyAZP
Geometry: Point
Feature Count: 3706
Extent: (3684408.169759, 5649780.912223) - (3713994.793069, 5681324.917881)
Layer SRS WKT:
PROJCS["PUWG_65_Strefa_IV",
    GEOGCS["GCS_Pulkovo_1942",
        DATUM["Pulkovo_1942",
            SPHEROID["Krasovsky_1940",6378245.0,298.3]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Double_Stereographic"],
    PARAMETER["False_Easting",3703000.0],
    PARAMETER["False_Northing",5627000.0],
    PARAMETER["Central_Meridian",16.67222222222222],
    PARAMETER["Scale_Factor",0.9998],
    PARAMETER["Latitude_Of_Origin",51.67083333333333],
    UNIT["Meter",1.0]]
ArkuszAZP: String (50.0)
Nr_punktu: String (50.0)
g.proj
-PROJ_INFO-------------------------------------------------
proj       : sterea
ellps      : krassovsky
lat_0      : 51.67083333333333
lon_0      : 16.67222222222222
k          : 0.999800
x_0        : 3703000
y_0        : 5627000
towgs84    : 33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : metre
units      : metres
meters     : 1
nevermind that problem, I will exprot it from Arc As txt and import to grass
as xyz. I rather point it as an error I recived
But If you found something interesting please let me know...
regards
JArek
