[GRASS-user] zone statistics ?
Dylan Beaudette dylan.beaudette at gmail.com
Mon Jan 8 12:52:24 EST 2007
Hi Didrik,
On Monday 08 January 2007 05:29, Didrik Pinte wrote:
> Hi,
> Is it possible to get kind of zonal statistics in Grass ? I don't know
> if the term is the rigth one, but here is what I want to do.
I think that zonal statistics are usually defined in terms of
Univariate statistics computed from some source raster, within zones as
defined by either raster or vector data. I do not think that having only
vector data as input should be a problem.
> I have two vector layers. I want to update the first layer using
> information from the second layer.
> Ex.
> Layer_2 is a network of cells with an average pumping rate.
'network of cells' ?? what exactly does this mean? are these points, polygons?
> If cell_1 of layer_1 overlaps cell_2 and cell_3 in layer_2, I want the
> average pumping rate of cell_1 to be a spatial mean of the pumping rates
> of cell_2 and cell_3 according to their surface in cell1.
what is Layer_1 ? some sort of polygon boundary?
> Is it clear enough ?
not for me.
> I'm sure there is a pretty straigthforward way to do this in grass but I
> haven't found it.
> Thank you all in advance for the help.
> Didrik
> Ps : I'm running Grass 6.2.0 (Debian/Sid).
I the solution in GRASS is most likely a raster operation, so careful
conversion with v.to.rast and r.to.vect might be required for at least one
layer. Optionally, if your zones are defined with polygon data, and
your 'data_to_be_summarized' are raster- then a program called 'starspan' may
be of interest to you.
Good luck,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
