[GRASS-user] raster query on the basis of its labels
temiz temiz at deprem.gov.tr
Wed Jan 10 13:16:40 EST 2007
Jachym Cepicky wrote:
> hi,
>     if( @map, 1,0)
> should work
> jachym
> On Tue, Jan 09, 2007 at 01:44:51PM -0500, temiz wrote:
>> hello
>> I want to query my raster map on the basis of its labels using regular
>> expression.
>> something like:
>> r.mapcalc map="if(labels~'xxx',1,0)"
>> is it poosible ?
>> regards
>> Ahmet Temiz
>> This message has been scanned for viruses and
>> dangerous content by MailScanner, and is
>> believed to be clean.
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
thank you
But I think I need to give you more detail
my raster map is actually a geological map and includes so many rock
type categories ( over 100).
something like this: (of course they are not separete fields)
97      Tkisd         claystone-siltstone-sandstone (rock type )  eocene
if I want to query my raster map on its rock type. Say,  to display rock
group containing claystone. what should I do  ?
I can do it on vector map using sql.
But I have to stay in raster side. Because I analyse the areas
containing claystone and its slope angle higher than 20 deg
(another raster map).
shortly I need a command  like this:
r.mapcalc result="if((@map ~ 'claystone' && slp> 30),1,0))    # regular
expression on a text  and this claystone exists
in many rock group. So using cat numbers is not practical.
I think r.mapcalc makes query on numerical values.
so what might be solution be ?
regards
Ahmet Temiz
