[GRASS-user] v.overlay attribute table problem
Didrik Pinte dpinte at itae.be
Wed Jan 10 09:14:37 EST 2007
Stranger,
I've tested the following : create the intersection from layer B to
layer A compared with intersection from layer A to layer B :
CASE 1 :
v.overlay ainput=mpnetwork atype=area binput=management_polygones
atype=area output=base_cells operator=and
CASE 2 :
v.overlay ainput=management_polygones atype=area binput=mpnetwork
The resulting intersection are different and seems to be uncorrect :
CASE 1 :
GRASS 6.2.0 (ALMERIA):~/Documents/ucl/alert/grass > v.db.select
map=base_cells column=a_cat,b_cat,a_area_tot,b_area_tot where="a_cat=37"
a_cat|b_cat|a_area_tot|b_area_tot
37|10|1000000|15000
37|13|1000000|0
37|1|1000000|0
37|8|1000000|0
37|14|1000000|0
37|11|1000000|1527000
CASE 2 :
map=base_cells column=a_cat,b_cat,a_area_tot,b_area_tot where="b_cat=37"
... this is a very strange behaviour ... the CASE 1 gives the correct
intersection and not the CASE2 ...
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070110/5c2550db/attachment.bin
