[GRASS-user] gis.m: file ppm not found
Michael Barton michael.barton at asu.edu
Fri Jan 12 17:21:21 EST 2007
Eric et al.
Any chance that the problem lies in the string 'mapname at mapsetname'??
That is, are these maps either 1) in a different mapset than the currently
active one and/or 2) is there something unusual about the mapset or map name
(contains spaces, characters with diacritical marks, etc.)?
There has been some discussion recently on such issues and I wonder if a
patch was made that causes problems along these lines?
Michael
On 1/12/07 7:32 AM, "Patton, Eric" <epatton at nrcan.gc.ca> wrote:
> I noticed this ppm problem after I had added a vector to gis.m, renamed the
> table in sqlite (for whatever reason), and attempted to redisplay the vector
> without updating the database connection. I think it can also reproduced by
> adding a vector to gis.m, then renaming the vector using g.rename, and
> refreshing the map display while leaving the old vector name in the gis.m
> table of contents.
> ~ Eric.
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> To: Michael Barton; Martin Wegmann; grass user
> Sent: 1/12/2007 6:24 AM
> Subject: Re: [GRASS-user] gis.m: file ppm not found
> Hi all,
> I've found the same problem after compiling the January 6 snapshot in
> a ppc Mac with XCode provided by www.kyngchaos.com. In my case the
> same mapsets work with Grass6.2 and the latest 6.3 binary from the
> www.kyngchaos.com.
> Agustin
>> Since this works with Spearfish but not with some other locations,
> my first
>> suspect would be a permissions problem.
>> To do the graphic display, the GUI needs to send d.* output to
> *.ppm files
>> in .../$MAPSET/tmp/[userpid] -- whatever is specified by g.tempfile.
>> If there are permission problems, this would not work.
>> Another potential problem might be with the GRASS environmental
> variables
>> that set the output to a PPM file rather than an xdisplay.
>> Michael
>> On 1/11/07 7:51 AM, "Martin Wegmann" <wegmann at biozentrum.uni-
> wuerzburg.de>
>> wrote:
>>> Hello,
>>> I did a GRASS 6.3 cvs update one hour ago and now I cannot
> display maps
>>> (raster/vector) anymore. The error message "file *.ppm not found"
> appears.
>>> But that happens only in some locations, if I use spearfish it
> works fine.
>>> BTW I can display my maps via d.mon-d.rast commands hence I think
> it is a
>>> gis.m problem.
>>> any idea, how to fix this?
>>> thanks in advance, Martin
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Dr. Agustín Diez Castillo
> Departament de Prehistòria i Arqueologia
> Universitat de València    Phone:   +34 963 86 42 42
> Avda. Blasco Ibañez, 28   Fax:      +34 963 86 42 34
> València 46010
Center for Social Dynamics & Complexity
phone: 480-965-6213
fax: 480-965-7671
