[GRASS-user] Re: gis.m: file ppm not found - Fixed (confirmed)
Stefan Paulick stefan.paulick at urbeli.com
Mon Jan 15 00:56:07 EST 2007
Yes, the failure condition has gone for the latlon region.
Thank you very much!
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Michael Barton schrieb:
> I think I tracked this down. It seems to be the a problem in latlon regions
> resulting from a recent fix I did to deal with changes in the behavior of
> g.region. I think I fixed it. I just commited this to the cvs.
> Michael
> On 1/12/07 5:23 PM, "Tomas Lanczos" <lanczos at t-zones.sk> wrote:
>>> From: Michael Barton [mailto:michael.barton at asu.edu]
>>> The same would happen for rasters if the map name for the
>>> layer doesn't match a valid raster map. Any idea about the
>>> validity of your maps or the name or your mapset?
>> I did not change any map name in this mapset. For expample, just this
>> morning started Grass 6.3, opened the raster and got an errormessage, I did
>> not have this problem yesterday, the Grass worked with the same map without
>> problem. The same is with the vectors, last Sunday I did a lot of
>> intersection between different vectors - once the errormessage came after
>> the 15th redraw command, next time after the second one and then worked fine
>> until lunch, after lunch three times, then worked fine for two hours, etc.
>> Regards
>> Tomas
>>> Michael
>>> On 1/12/07 3:47 PM, "Tomas Lanczos" <lanczos at t-zones.sk> wrote:
>>>> I am getting this errormessage, but accidentally, even I
>>> don't touch
>>>> any vector, even I am working only  with rasters. I could
>>> not find any
>>>> causality.
>>> __________________________________________
>>> Michael Barton, Professor of Anthropology School of Human
>>> Evolution & Social Change Center for Social Dynamics &
>>> Complexity Arizona State University
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>> www: http://www.public.asu.edu/~cmbarton
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> phone: 480-965-6213
> fax: 480-965-7671
