[GRASS-user] v.overlay attribute table problem [SOLVED]
Didrik Pinte dpinte at itae.be
Mon Jan 15 04:20:44 EST 2007
Le jeudi 11 janvier 2007 à 17:08 +0100, Didrik Pinte a écrit :
> I've made some progress :
> Using two grid generated to test the intersection problem, I get correct
> intersection and correct attribute table.
> So the problem is related to the input file I'm using...
> Here is a screenshot of the two layers :
> http://downloads.itae.be/grass_overlay.jpg
> Is there any reason why the overlay operation seems to be correctly done
> but the attribute table is not correctly created ?
> Didrik
After lots of investigation, it seems all of this was related to the use
of the DBF backend.
I've switched to postgres and everything works fine now.
I've reported a bug on the grass bugtracker but I cannot add comments to
it. Does anybody knows how to get a login on Intevation RT ?
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070115/cbc66c9d/attachment.bin
