[GRASS-user] v.surf.rst generates negative value
Maciej Sieczka tutey at o2.pl
Tue Jan 16 12:22:05 EST 2007
temiz wrote:
> I created DEM using spline and tension.
> But although contour map does not have any negative value, v.surf.rst
> generates negative altitudes.
> can you tell me why ?
Temiz
Can you put a sample + region settings + v.surf.rst syntax so somebody
can try to reproduce?
Maciek
