[GRASS-user] ps.map: different locations and one document possible?
Wed Jan 17 15:29:59 EST 2007
wqual wrote:
> I successfully created a map using the ps.map-command. However, I need to add
> another layer (background theme) which is in a different location (but same
> coordinate system). Is there a way to include this layer in my map using
> ps.map without having to import it into the current location?
No, it isn't.
However, you may be able to combine two PostScript files with e.g.
Adobe Illustrator, or even by manually inserting the relevant portion
of the second file into the first (the viability of the latter option
depends upon how well structured the PostScript code is).
