[GRASS-user] Newbie: Errors Compiling CVS:grass 6.3 on suse 10.2
Fri Jan 19 10:27:59 EST 2007
andrew.haywood at poyry.com wrote:
> I am having problems compiling the latest weekly 6.3-CVS source code
> snapshot. This is the first time I have tried to compile from source - so
> its definitely me!!!. Things seem to go OK when I run the below script.
> but when I run "make install" i get a number of errors along the lines of
> "ERROR: Mapset permanent - permission denied". I have run the "make
> install" as root. Any suggestions on how to fix this would be greatly
> appreciated.
Please provide more details, primarily the commands which generate the
error. Save the output from "make install" to a file with e.g. "make
install &> install.log", then post the file.
