[GRASS-user] compiling 6.3 cvs on ubuntu 64bit
Sun Jan 21 18:21:30 EST 2007
Malte Halbey-Martin wrote:
> the line was just an example of the error. In fact in every line is a
> syntax error before ftnlen  and L_fp...
Ah. In that case, my first guess would be that you're trying to use
gcc 4.x, whose Fortran support is essentially broken. You need to use
gcc 3.x if you want to use BLAS/LAPACK.
