[GRASS-user] new to GRASS
savitri negi savitrinegi1 at rediffmail.com
Mon Jan 22 23:58:29 EST 2007
  hi all
can anybody tell me what is command d.extend used for ?
till ystrday i was nt able to display  a .tif file even after setting region for raster but then i gave the d.extend command after d.rast and was able to display the image on x mon0
I dont know if d.extend really helped to display the contents of the .tif image as earlier i was just able tos ee a black screen on the xmon
not the contents..
anyways thanx to all
i am able to display the image now ,n now trying to explore more of GRASS
savitri
DEAL,India
On Mon, 22 Jan 2007 Otto Dassau wrote :
>Hi,
>On 22 Jan 2007 07:18:00 -0000
>"savitri  negi" <savitrinegi1 at rediffmail.com> wrote:
> > hello all
> > iam quite new to GRASS infact i started it jst a few days back
> > i downloaded  the source GRASS 6.2.1 source code n compiled it on my redhat
>enterprise linux machine and i was able to start GRASS
> > n started using it.
> > i also istalled the two mandatory gdal n other library
> > now say i want to display just a .tif image i did the following
> > i selected the database   a location and a mapset at startup screen after
>which i was able to see the GIS manager GUI
> > i have got say a .tif image.
> > 1  ..converted the .tif image into raster using r.in.gdal input=filename.tif
>output =output raster image name
> > 2  ..started the monitor x0 as d.mon x0
>using d.mon you might need a further step here to set the extend of your current
>region to the tif before you display it.
>g.region rast=output_raster_image_name
>hth,
>  Otto
> > 3  ...tried to diplay image on mon using d.rast= outut raster image name
> >  but iam unable to see anything in the x0 monitor  though the whole process
>dint showd any errors
> > though wen i change the background  color in d.rast window i can see a
>coloured surface of size of my original image on x0 but not the real image
> > ,being quite new to the GIS field iam not able to figure out wat am i missing
> > right now i just wanted to display a tif image  or may be a .img file on the
>monitorr
> > which iam not able to do
> > may be anyone of u could help
> > Savitri negi
> > DEAL,india
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070123/b90af577/attachment.html
