[GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Tue Jan 23 11:20:23 EST 2007
Patton, Eric wrote:
> configure: error: --with-grass=/usr/local/grass-6.3.cvs requested, but
> libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to include
> /usr/local/grass-6.3.cvs/lib?
Eric,
This suggestion is just a perhaps.  Generally it means things failed
to link and you can dig into the config.log to find out details.  I
suspect the problem is that grass is built against the old GDAL so
attempts to link the driver against grass libraries fails because the
old gdal library can't be found.
If that is the problem, you may need to rebuild and install GRASS using
the new GDAL libraries before trying to rebuild the grass-gdal driver.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
