[GRASS-user] gdal_version.h for gdal-1.2.5-1.i586.rpm
Otto Dassau otto.dassau at gmx.de
Wed Jan 24 02:44:49 EST 2007
Hi Lawrence,
the rpm is pretty old and was compiled on a Suse 9.1 (June, 2005). The
dependencies probably don't fail because there aren't really any included in
the SPEC file, except these:
BuildRequires: proj, python, zlib-devel
Requires: proj, zlib, python
BTW: the related GRASS package was grass-6.0.0.
Maybe you should create your own gdal rpm for RHEL3/CentOS3 with a appropriate
SPEC file or somebody has a matching package for your distribution. The gdal
1.2.5 suse package is not a good choice - I think...
Maybe you can adapt a fedora4 spec file to your needs from here:
http://grass.itc.it/grass62/binary/linux/
regards,
 Otto
On Tue, 23 Jan 2007 23:10:45 -0500 (EST)
Lawrence Houston <grass at greenfield.dyndns.org> wrote:
> GRASS Users:
> The only GDAL RPM I found which does NOT fail dependencies when installing
> under RHEL3/CentOS3 is an older one which I downloaded a while back, which
> I can NOT locate now in my Web Searching: gdal-1.2.5-1.i586.rpm (which was
> for an older Release of GRASS, possibly for a SuSE 9x Build of
> GRASS6.0???):
> Name        : gdal                         Relocations: /usr/local
> Version     : 1.2.5                             Vendor: GDF Hannover bR
<http://www.gdf-hannover.de>
> Release     : 1                             Build Date: Mon 07 Feb 2005
08:15:39 AM EST
> Install Date: (not installed)               Build Host: tatzi
> Group       : Applications/GIS              Source RPM: gdal-1.2.5-1.src.rpm
> Size        : 10267601                         License: MIT licence;
> Copyright by Frank Warmerdam
> Signature   : (none)
> Packager    : Otto Dassau <info at gdf-hannover.de>
> URL         : http://gdal.org/
> Summary     : GDAL - a translator library for raster geospatial data
> formats
> Description :
> GDAL is a translator library for raster geospatial data formats. As a library,
> it presents a single abstract data model to the calling application for all
> supported formats. An initial skeleton of GDAL has formed, and operates for a
> few formats.
> Although configure is satisfied with the presence of GDAL, at build time
> there is a missing "gdal_version.h" which causes some of the Vector
> Modules to fail at compile time...  I fashioned an "gdal_version.h" after
> the "gdal_version.h" included within the newer GDAL RPMs, after which my
> GRASS 6.2.1 Build reports NO Errors???  My hand crafted "gdal_version.h"
> looks as follows:
> /*      GDAL Version Information.                                       */
> #ifndef GDAL_VERSION_MAJOR
> #  define GDAL_VERSION_MAJOR    1
> #  define GDAL_VERSION_MINOR    2
> #  define GDAL_VERSION_REV      5
> #  define GDAL_VERSION_BUILD    1
> #endif
> #ifndef GDAL_VERSION_NUM
> #  define GDAL_VERSION_NUM
(GDAL_VERSION_MAJOR*1000+GDAL_VERSION_MINOR*100+GDAL_VERSION_REV*10+GDAL_VERSIO
N_BUILD)
> #endif
> #ifndef GDAL_RELEASE_DATE
> #  define GDAL_RELEASE_DATE     20041121
> #endif
> #ifndef GDAL_RELEASE_NAME
> #  define GDAL_RELEASE_NAME     "1.2.5.1"
> #endif
> Should GRASS 6.2.1 built against GDAL 1.2.5 produce Vector Routines which
> will perform "correctly" or should it be built against a newer version (in
> spite of being unable to find a RPM which does NOT fail dependencies
> installing under RHEL3/CentOS3???  Could the GRASS 6.2 Code be made smart
> enough the be able to handle the lack of a "gdal_version.h" for GDAL 1.2.5
> (previous GRASS Releases did build without errors against this "older"
> version of GDAL)???
> Lawrence Houston  --  (grass at greenfield.dyndns.org)
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
