[GRASS-user] Re: Kyngesburye GRASS 6.2.1-2 Mac OS X Binary: Framework trouble
William A. Perkins william.perkins at pnl.gov
Wed Jan 24 13:25:03 EST 2007
>>>>> "Bill" == William A Perkins <william.perkins at pnl.gov> writes:
    Bill> Hello,
    Bill> I'm using OSX 10.4.8 on a G5 system. I downloaded and installed "All
    Bill> Frameworks" package and the GRASS 6.2.1-2 application.  These are
    Bill> dated January 21.  Before I installed the frameworks packages, I
    Bill> removed the old ones I had (by dragging them to the trash). BTW, I
    Bill> installed the old frameworks for a previous version of QGIS, not
    Bill> grass.
    Bill> When I start GRASS.app, gis.m does not start, but I get a command
    Bill> line.  I cannot run any commands because it appears to need an older
    Bill> version of the GDAL framework.  Here's an example:
    Bill>     Mapset <Imagery> in Location <SnakeSpawning>
    Bill>     GRASS 6.2.1 > g.list rast
    Bill>     dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.3/GDAL
    Bill>       Referenced from: /Applications/GRASS/GRASS.app/Contents/Resources/bin/g.list
    Bill>       Reason: image not found
    Bill>     Trace/BPT trap
    Bill> The GDAL framework I installed appears to be 1.4:
    Bill>     GRASS 6.2.1 > ls /Library/Frameworks/GDAL.framework/Versions/
    Bill>     total 4
    Bill>     0 ./  0 ../  0 1.4/  4 Current@
    Bill> Any help would be appreciated.
    Bill> Thank you.
    Bill> Bill
    Bill> --
    Bill> Bill Perkins
    Bill> Pacific Northwest National Laboratory
    Bill> Environmental Technologies Division, Hydrology Group
    Bill> P.O. Box 999 MSIN K9-36
    Bill> Richland, Washington, USA  99352
    Bill> voice: (509) 372-6131 fax: (509) 372-6089 email: william.perkins at pnl.gov
Hello,
I should have mentioned that I can run the CVS GRASS application (from
GRASS.app-6.3.CVS.070121-1.dmg) fine.  Maybe that's the solution.
Bill
Bill Perkins
