[GRASS-user] compiling 6.3 cvs on ubuntu 64bit
Maciej Sieczka tutey at o2.pl
Wed Jan 24 15:35:14 EST 2007
Glynn Clements wrote:
> Malte Halbey-Martin wrote:
>> the line was just an example of the error. In fact in every line is a
>> syntax error before ftnlen  and L_fp...
> Ah. In that case, my first guess would be that you're trying to use
> gcc 4.x, whose Fortran support is essentially broken.
Glynn,
Does that mean that i.fft and i.fft will not build or work properly
using gfortran coming with GCC 4.0.3? Is that an issue only with 64 bit
systems?
Maciek
