[GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Patton, Eric epatton at nrcan.gc.ca
Thu Jan 25 09:13:55 EST 2007
Thanks to everyone for their replies, the issue I was having with my gdal plugin not compiling was that I had two versions of geos installed (unbeknownst to me). Removing one allowed the plugin to compile normally.
Thanks guys!
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: grassuser at grass.itc.it
Sent: 1/24/2007 5:44 PM
Subject: Re: [GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Patton, Eric wrote:
> I recently had to recompile gdal so that support for ECW was
> enabled. I decided since I was changing my compile line, I would
> upgrade from gdal-1.3.2 to gdal-1.4.0 in the process. I ran make
> distclean in my gdal-1.3.2 directory, then configure, make, and make
> install in gdal-1.4.0, all of which proceeded without errors.
> gdalinfo --formats reports a normal listing of supported file types.
> Grass compiles and installs normally as well.
> The trouble lies with the gdal-grass plugin. An error occurs during
> compilation, reporting
> configure: error: --with-grass=/usr/local/grass-6.3.cvs requested,
> but libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to
> include /usr/local/grass-6.3.cvs/lib?
Eric,
Look into this thread:
http://www.nabble.com/gdal-grass-plugin-fails-during-.-configure-with-GR
ASS-6.3-CVS-tf2904760.html#a8115150
Maybe there's some help.
Maciek
