[GRASS-user] grass database in windows
Richard Greenwood richard.greenwood at gmail.com
Fri Jan 26 22:09:19 EST 2007
On 1/25/07, Patricio Antonio Toledo Peña
<patricioantoniotoledo at gmail.com> wrote:
> Hi, I have a grass database in a computer with windows (don't ask me why
> is a long history).
> I shared this database with samba. I mounted this database on
> a computer with linux (is it clear?) where i run grass62.
> The problem is that when i tried to import xyz points with v.in.ascii
> it fails to fill the vector with data, no error report it is just an empty
> vector. I tested the same command but this time
> with the database on a computer with linux, not mount involved. Then
> it runs ok.
> Which is the problem?
> Best Regards
Maybe it is permissions. On the windows computer, change the ownership
of all of the GRASS files to whoever the samba user is. Then on the
Linux computer, login as that user.
Richard Greenwood
www.greenwoodmap.com
