[GRASS-user] Broken vector file??
Radomir dod.mort at gmail.com
Sat Jan 27 13:33:42 EST 2007
Dnia 27-01-2007, sob o godzinie 18:39 +0100, Maciej Sieczka napisał(a):
> Radomir wrote:
> > Hi,
> > I'm quite new in GRASS so please be patient :)
> > I've imported my Mapinfo vector file into new GRASS vecotor with
> > atribute table in Mysql. Everything was fine until I've edited GRASS
> > vector in Qgis and added some points. After this, all operations are
> > finising with the following error:
> > Cannot open old vector transform_izolinie3d at mort on level 2
> > Still I have all data in MySQL. Is it possible to fix it??
> Radomir,
> Propably QGIS crashed when you edited the vector. No worries - you most
> likely didn't loose any data. Everything you edited until the crash is
> should be still there.
> To resurrect the vector do "v.build your_broken_vector". If the output
> of that command includes a warning about an too big coor file, open
> your_broken_vector in eg. v.digit, and close it - this will fix it for
> good.
> > I've tried google but I couldn't find anything helpful,
> Better use one of the archive search engines for GRASS lists, eg.
> http://www.nabble.com/GRASS-f1200.html.
> Maciek
Maciek,
You're right. Now it works, :)
Thanke you
Radomir
The Future Is Now ;)
