[GRASS-user] Raster aggregation with r.neighbors
Tue Jan 30 06:06:17 EST 2007
Patrick Meyfroidt wrote:
> I used also the r.statistics method, but it was very time-consuming
> to create a base raster map at the desired resolution (I foudn a
> procedure here in the archive: creating two grids in a spreadsheet
> editor, one with cell value being the x-coordinate, and the other
> with cell value being the y-coordinate, and then combine them). And
> if I want to make tests with other resolutions (say, 6, 7, 8 km
> instead of 5 km), I need to re-do the same long procedure.
> Is there a simple and fast way to create a raster map with unique
> cell values (one category for each cell)? With some r.mapcalc trick?
Two options spring to mind:
1. Diagonal numbering:
	r.mapcalc 'basemap=eval(r=row(),c=col(),n=r+c-1,r+n*(n-1)/2)'
2. Raster numbering:
	eval `g.region -g`
	r.mapcalc "basemap=(row()-1)*$cols+col()"
Note the use of double quotes in the second case, to allow $cols to be
expanded by the shell.
Whilst #1 is simpler, it is slightly more sparse (the highest category
will be roughly twice that for #2), and so will overflow the range of
a signed integer earlier (you are limited to ~33000 rows/cols for #1
vs ~46000 for #2).
