[GRASS-user] capacity
Michael Perdue michael_perdue at yahoo.ca
Thu Jul 5 17:44:38 EDT 2007
Aaron,
So, If I understand you correctly, you have 800 raster files that you
need to re-scale but are failing due to the length of the list or
command line length?
If your files are named in a logically/sequential fashion (foobar_1 ,
foobar_2 , foobar_3 etc) then you could run your commands on each
file using a counter inside a loop. pseudo code would look something
like;
let counter=1
while [ ${counter} -le 800 ]; do
	r.region map=foobar_${counter} n= s= e= w=
	counter=${counter}+1
done
However, if the file names are unorganized then you may need to
rework the file names outside of GRASS using a batch re-namer in
order to get this to work.
Cheers,
Mike
On 5-Jul-07, at 8:51 AM, goldneaa at onid.orst.edu wrote:
> I am dealing with a lot of raster files at once.  When I have used
> certain commands like g.mlist for listing of my raster files, it
> has given me warmings like, "file name too long."  Similar problems
> have arose when I use r.region to change location of my raster
> files.  Is there a capacity to the program when adjusting a lot of
> raster files at once, and is there a way around not getting these
> warnings.
> Aaron
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070705/6be7183e/attachment.html
