[GRASS-user] cvs make problems
Jerry Nelson gnelson at uiuc.edu
Mon Jul 9 15:38:59 EDT 2007
Tried adding 64 and removing the readline stuff. Started from make
distclean. Still getting the same set of errors.
This error message is puzzling
> cp: cannot create regular file
`../dist.x86_64-unknown-linux-gnu/docs/html/nviz/': Is a directory
Is there some string completion command that is missing a variable?
Jerry
-----Original Message-----
From: Brad Douglas [mailto:rez at touchofmadness.com]
Sent: Monday, July 09, 2007 12:31 PM
To: Gerald Nelson
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] cvs make problems
Try using '-mcpu=athlon64'.  I have a similar system which compiles
fine.  Let me know if you still have problems.
BTW, you don't really need readline.  IIRC, it's only used in r.mapcalc
for command history.
On Mon, 2007-07-09 at 11:16 -0500, Gerald Nelson wrote:
> I have a new computer with an AMD 64 Athlon X2 chip and a gig of ram. I
want to install 6.3 cvs with 64 bit support. The steps I have followed (more
or less are )
> - cvs update (today)
> - run CFLAGS="-O2 -mcpu=athlon -Wall" LDFLAGS="-s"
> - configure with the options listed below
>  ./configure \
>            --enable-largefile                                    \
>            --with-postgres-includes=/usr/local/pgsql/include/    \
>            --with-proj-includes=/usr/local/include/              \
>            --with-proj-share=/usr/share/proj/                    \
>            --with-postgres-libs=/usr/local/pgsql/lib/            \
>            --with-readline-libs=/usr/local/lib/                  \
>            --with-readline-includes=/usr/local/include/readline/ \
>            --enable-64bit/                                       \
>            --with-libs=/usr/lib64                               \
>            --with-readline=yes
> - make
> The make returns error 1. The first place I can find with a problem
(although I haven't dumped the output to a text file is
> Makefile:108: warning: overriding commands for target `clean'
> ../include/Make/Rules.make:34: warning: ignoring old commands for target
`clean'
> make[1]: Leaving directory `/usr/local/grass6/macosx'
> if [ 0 -eq 1 ] ; then make -C locale; fi
> cp -f AUTHORS COPYING README REQUIREMENTS.html
/usr/local/grass6/dist.x86_64-unknown-linux-gnu/
> cp -f /usr/local/grass6/bin.x86_64-unknown-linux-gnu/grass63
/usr/local/grass6/dist.x86_64-unknown-linux-gnu/grass63.tmp
> build_html_index.sh
> chmod: cannot access
`../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grassdocs.css': No such
file or directory
`../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grass_logo.png': No such
file or directory
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
