[GRASS-user] Water Polygon Issue
M S mseibel at gmail.com
Mon Jul 23 07:47:07 EDT 2007
Does the water polygon display any solid fill (area) color?
Is the water polygon built for polygons/areas?  If not, and they are closed
lines, you can build them with v.build.  If the data is not closed lines,
and you can afford for the data to move slightly to have GRASS snap and
close polygons, you can use v.clean.
On 7/23/07, Ryan Rosario <uclamathguy at gmail.com> wrote:
> I have a layer called "county" to which I assign a color and the polygon
> is correctly colored on the display. Unfortunately, this county layer also
> includes part of the ocean that is regulated by the county. I want to
> eliminate this by overlaying the water polygon for the county and assigning
> it white as a background color so only the county land (excluding water)
> will appear displayed.
> When I assign a color to the water polygon layer, nothing happens. The
> layer does not change color. It is as if this layer only defines the outline
> of the water. Is there a way I can get GRASS to color in this layer so I can
> achieve what I am looking for?
> Thanks,
> Ryan
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070723/3b3975db/attachment.html
