[GRASS-user] r.to.rast3
bks at centrum.cz bks at centrum.cz
Fri Jul 27 11:31:16 EDT 2007
Thanks for the answer.
The reason I am trying to do that is really simple. Perhaps, can you give me some recommandations...
I would like to get a simple visualization of  only one soil horizon depth in few transects. 2d is good enough...
I have his depth raster (depth from surface) and surface elevation.
Thank you in advance.
Stanislav
______________________________________________________________
> Od: soerengebbert at googlemail.com
> Komu: "bks at centrum.cz" <bks at centrum.cz>
> Datum: 27.07.2007 12:28
> Předmět: Re: [GRASS-user] r.to.rast3
>Hi,
>i guess the number of open file handler is
>the limiting factor in this case. Looks like the limit is 1024?
>I don't know if r.to.rast3 has any influence on this.
>And i don't know if you can increase the number of
>open file handler's on your system.
>I don't think that i am able to provide a patch
>or a workaround in the next weeks or months.
>What you can do is to try a lower z resolution, maybe 0.034
>or something to avoid 3100 depths. Because each map is
>opened for each depth.
>Soeren
>2007/7/26, bks at centrum.cz <bks at centrum.cz>:
>> Hi,
>> I have installed 6.2.2 but it didn't solved the problem "r.to.rast3". I
do
>> not know, what I am doing badly....
>> Here are details:
>> GRASS 6.2.2cvs (lokvrst102):~ > r.to.rast3 input=elev_bas,elev_surf
>> output=rast3_epipedon --overwrite
>> Open raster map elev_surf - one time for each depth (1/3100)
>> Open raster map elev_surf - one time for each depth (1017/3100)
>> Open raster map elev_surf - one time for each depth (1018/3100)
>> Open raster map elev_surf - one time for each depth (1019/3100)
>> Open raster map elev_surf - one time for each depth (1020/3100)
>> WARNING: Unable to open
>>          /home/bekas/lokvrst102/PERMANENT/cell_misc/elev_surf/f_format
>> WARNING: quantization file [elev_surf] in mapset [PERMANENT] missing
>> WARNING: Can't open header file for [MASK in PERMANENT]
>> ERROR: Input maps have to be from the same type. CELL, FCELL or DCELL!
>> [Raster MASK present]
>> GRASS 6.2.2cvs (lokvrst102):~ > g.region -p3
>> projection: 0 (x,y)
>> zone:       0
>> north:      -1188163.21777146
>> south:      -1188428.35974525
>> west:       -581335.49616366
>> east:       -581170.41708042
>> top:        246.00000000
>> bottom:     215.00000000
>> nsres:      1.00053575
>> nsres3:     1.00053575
>> ewres:      1.00047929
>> ewres3:     1.00047929
>> tbres:      0.01
>> rows:       265
>> rows3:      265
>> cols:       165
>> cols3:      165
>> depths:     3100
>> cells:      43725
>> 3dcells:    135547500
>> Layer:    elev_bas                       Date: Thu Jul 26 19:27:20
>> 2007    |
>> | Mapset:   PERMANENT                      Login of Creator:
>> bekas           |
>> | Location:
>> lokvrst102                                                       |
>> | DataBase:
>> /home/bekas                                                      |
>> | Title:     ( elev_bas
>> | timestamp:
>> none                                                            |
>> |   Type of Map:  raster               Number of Categories:
>> 255             |
>> |   Data
>> Type:    DCELL                                                      |
>> |   Rows:
>> 265                                                        |
>> Columns:      165
>> |   Total
>> Cells:  43725                                                      |
>> |        Projection: x,y (zone
>> 0)                                            |
>> |            N: -1188163.21777146    S: -1188428.35974525   Res:
>> 1.00053575  |
>> |            E: -581170.41708042    W: -581335.49616366   Res:
1.00047929
>> |   Range of data:    min = 216.996098  max = 243.984776
>> |   Data
>> Source:                                                             |
>> |   Data
>> Description:                                                        |
>> |    generated by r.mapcalc
>> Comments:
>> |    elev_d20 - epiped.cm
>> | Layer:    elev_surf                      Date: Thu Jul 26 19:28:20
>> 2007    |
>> bekas           |
>> | Location:
>> lokvrst102                                                       |
>> | DataBase:
>> /home/bekas                                                      |
>> | Title:     ( elev_surf
>> | timestamp:
>> none                                                            |
>> 255             |
>> |   Data
>> Type:    DCELL                                                      |
>> |   Rows:
>> 265                                                        |
>> Columns:      165
>> |   Total
>> Cells:  43725                                                      |
>> 0)                                            |
>> 1.00053575  |
1.00047929
>> |   Range of data:    min = 217.848999  max = 244.296890
>> |   Data
>> Source:                                                             |
>> |   Data
>> Description:                                                        |
>> Comments:
>> |    elev_bas + epiped.cm
>> > Od: soerengebbert at gmx.de
>> > Komu: grassuser at grass.itc.it
>> > CC: bks at centrum.cz
>> > Datum: 23.07.2007 20:22
>> >Hi,
>> >i'm not able to reproduce this error with the latest cvs version of
>> grass6.
>> >It seems to work with integer, float and double raster maps.
>> >Can you please provide more information?
>> >1.) What version of grass are you using
>> >2.) The command line you have used
>> >3.) The projection and size of your mapset
>> >Best regards
>> >Soeren
>> >Am Freitag, 20. Juli 2007 18:26 schrieb bks at centrum.cz:
>> >> Hi,
>> >> I have a problem in  runing r.to.rast3.
>> >> I cannot go over the following error message: "Input maps have to be
>> from
>> >> the same type. CELL, FCELL, DCELL!"
>> >> The input 2D slice maps were made by r.mapcalc.
>> >> To fix the problem I have tried to:  r.mapcalc "map1=float(map1)"
and
>> the
>> >> with map2.
>> >> r.info .... from both of them show:  data type: FCELL
>> >> It doesn't help.
>> >> Wenn I work with integer (CELL), I receive this error message:
"Could
>> not
>> >> open map ... (allway the second one
>> >> >from the two input ones)"
>> >> Thanks in advance for your help!
>> >> Stanislav
>> >> grassuser mailing list
>> >> http://grass.itc.it/mailman/listinfo/grassuser
