[GRASS-user] circle surrounding neighbors
Sun Jul 29 20:40:01 EDT 2007
bks at centrum.cz wrote:
> don't you know about any possibility to use something similar to r.neighbors
> but  for the circle surrounding of the pixel?
Modify raster/r.neighbors/gather.c.
An (untested) attempt is attached.
#include <grass/gis.h>
#include "ncb.h"
   given the starting col of the neighborhood,
   copy the cell values from the bufs into the array of values
   and return the number of values copied.
static char **mask;
static void init_mask(void)
    int i, j;
    if (mask)
	return;
    mask = G_malloc(ncb.nsize * sizeof(char *));
    for (i = 0; i < ncb.nsize; i++)
	mask[i] = G_malloc(ncb.nsize);
	for (j = 0; j < ncb.nsize; j++)
	    mask[i][j] = sqr(i - ncb.dist) + sqr(j - ncb.dist) <= sqr(ncb.dist);
int gather(DCELL *values, int offset)
    int row, col;
    int n = 0;
    *values = 0;
    if (!mask)
	init_mask();
    for (row = 0; row < ncb.nsize; row++)
	for (col = 0; col < ncb.nsize; col++)
	    DCELL *c = &ncb.buf[row][offset + col];
	    if (!mask[row][col])
		continue;
	    if (G_is_d_null_value(c))
		G_set_d_null_value(&values[n], 1);
	    else
		values[n] = *c;
	    n++;
    return n ? n : -1;
