[GRASS-user] Re: Can't create location from file
Maciej Sieczka tutey at o2.pl
Sat Jun 16 16:44:53 EDT 2007
Daniel Victoria wrote:
> Just an update.
> I just noticed that grass is looking for the epsg file in
> /usr/local/share/proj and it's installed in /usr/share/proj. Could
> that be related?
You should put the path to where your "epsg" file resides into the
"Path to the EPSG codes file" dialog. The file comes with PROJ.4.
> Also, the geotiff has several epsg codes in it and
> the only one valid is 4326.
Your gdalinfo output seems corrupted. Compare with the output of
"epsg_tr.py 4326" to see the difference. It is missing EPSG codes for
prime meridian and unit. That's propably why GRASS fails to creata a
location using it.
Also please note that only the last EPSG code designates the coordinate
system. Those coming before it are for the CS components, like
spheroid, datum etc.
> If I create a location with this EPSG code
> all goes fine. If I use the others, a tmp.<somenumber> directory is
> created.
That's because you are passing wrong EPSG coordinate system code, which
GRASS 6.2 can't handle and creates a corrupted location. As expected,
only "4326" works OK. In GRASS 6.3, using an invalid coordinate system
EPSG code yields an error message like on the attached screendump.
Please fill in a wish in the tracker for backporting this usefull
feature to GRASS 6.2. Maybe it will get included in 6.2.2 release.
Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070616/7cafea65/wrong_epsg_grass63.png
