[GRASS-user] v.in.gpsbabel into a UTM location
Ravinder Singh Bhalla rsbhalla at gmail.com
Fri Mar 2 05:47:31 EST 2007
Hi all,
I´m trying without success to pull in data from a garmin gps into a UTM
projected location using v.in.gpsbabel. I´ve tried to switch between
Lat/Long as well as UTM/UPS but the imported waypoints are always in
lat/long. Do I have to create a lat/long location and then export the
vectors or can I do it directly into the UTM location? If the latter is
possible, what options should I be trying?
Thanks in advance,
Ravi
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070302/80b69176/bhalla.vcf
