[GRASS-user] GRASS 6.2.1-1 Installation Question
Ramu Narayanan ramu.nm at gmail.com
Sun Mar 4 19:59:36 EST 2007
I have been able to use the Map Display Monitor UI as oppossed to typing in
d.mon for displaying raster maps.  I have not encountered much difficulty
with the UI when working with raster data.  Is there a text command that can
be used to select the UI Map Display Monitor?
When I use the UI to display a regular raster map, I see the following in
the Output window:
d.frame -e
d.rast map=<mapname> -o
g.pnmcomp in=####.#.ppm mask=####.#.pgm opacity=1.00 background=255:255:255
width=640 height=482 output=3648.1.ppm
The raster map loads up without problem.
however, when I type d.frame -e in the terminal, I get the same response
that no graphics monitor has been selected.
Thanks,
Ramu
On 2/20/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> Ramu Narayanan wrote:
> > Typing in d.mon -L indicates that the x0 monitor is not running after I
> type
> > d.mon x0
> > This is verified by trying d.mon stop=x0 which indicated that x0 was not
> > running.
> Both of these are reporting the fact that they cannot connect to the
> socket.
> > The only indication i see that it was running apart from the open window
> was
> > by trying d.mon select=x0 which indicates that 'socket is already in use
> or
> > is not accepting connections'.
> The window (and the presence of XDRIVER.exe in Windows' process list)
> implies that it is actually running.
> > I cannot close the monitor by hitting the close button.
> That implies that the process has hung and isn't processing X events.
> > I tried this before and after removing my firewall that I have installed
> but
> > without any changes in the resulting messages.
> > I found this link online which appears to indicate that there may be a
> > problem with xDriver when working with Gentoo but I'm not sure if it
> applies
> > to my situation:
> > http://blog.gmane.org/gmane.comp.gis.grass.user/month=20031101
> I couldn't find the post in question, but I use Gentoo, and haven't
> had any problems. Also, 2003 is a long time ago.
> > Is there something else that I might be able to try?
> Nothing springs to mind.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070304/3f83c774/attachment.html
