R: [GRASS-user] The print button in Map Display
Aldo Clerici alcl01 at ipruniv.cce.unipr.it
Tue Mar 6 04:15:05 EST 2007
Moritz,
the current region setting is the default one.
Anyway if the function works well with you and the other users, I'm sure
it's not a GRASS bug and I can concentrate in checking my system.
Many thanks
Aldo Clerici
> -----Messaggio originale-----
> Da: Moritz Lennert [mailto:mlennert at club.worldonline.be]
> Inviato: lunedì 5 marzo 2007 19.14
> A: aldo.clerici at unipr.it
> Cc: grassuser at grass.itc.it
> Oggetto: Re: [GRASS-user] The print button in Map Display
> On 05/03/07 18:42, Aldo Clerici wrote:
> > Dear GRASSusers,
> > I'm having strange results with the print button in Map
> Display. More
> > precisely i'm not able to print the entire picture displayed in the
> > Map Display. I changed the 'Preset paper type' and the
> 'Custom paper
> > size' in the panel but the resulting printed map shows
> dimensions that
> > seem not related to the selected values. That happens with GRASS6.2
> > and 6.3 whereas the same function works well in GRASS6.0.
> Did anyboy
> > face with the same problem?
> Maybe the print dialog uses the current region settings,
> which might not be the same as the zoom level in the Map display.
> Try "Set current region to map display" in the zoom drop-down
> menu of the map display.
> Moritz
