[GRASS-user] Spatial Statistics
Markus Neteler neteler at itc.it
Wed Mar 7 14:43:52 EST 2007
On Wed, Mar 07, 2007 at 06:38:09PM +0100, Dr. Manuel Seeger wrote:
> Markus Neteler schrieb:
> >Manuel,
> >v.rast.stats is your friend:
> > v.rast.stats - Calculates univariate statistics from a GRASS raster map
> > based on vector objects
> > http://grass.itc.it/grass63/manuals/html63_user/v.rast.stats.html
> >Hope this helps,
> >Markus
> Thank you!
> It works.
> But not really clean.
> if I try to let the module add the colums by itself, it creates an eroor
> after the first column, retrying it goes on and stops at the second etc.
Which error actually?
> so I have to repeat the procedure. The problem is, that on this way, it
> leaves temporary raster files within my mapset in use for every step...
This should not happen of course.
I see that an empty file is left behind, will check.
> Please excuse, but I dind not copy the error echo.
> Perhaps someone may reproduce it?
I just tried the example from the manual page, no problem.
Please tell us
- which error
- which GRASS version
- which operating system
Markus
> Again, thanks a lot!
> Manuel
> Dr. Manuel Seeger
> Wiss. Assistent 			Scientific Assistant
> Physische Geographie 			Dpt. of Physical Geography
> FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
> Universit?t Trier			University of Trier
> D - 54286 Trier
> Tel.:	+49-651-201 4557
> Fax:	+49-651-201 3976
> Web:	http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
