[GRASS-user] Spatial Statistics
Dr. Manuel Seeger seeger at uni-trier.de
Thu Mar 8 02:31:16 EST 2007
Hello all
> Please tell us
> - which error
The error is caused when I try to add the columns by v.rast.stats. This
is what it gives as report. I run it by gui:
Adding column <DGM_n>
/usr/lib/grass/scripts/v.db.addcol: 96: let: not found
DBMI-DBF driver error:
Column 'DGM_n' already exists (duplicate name)
Cannot add column.
Error in db_execute_immediate()
Error while executing: "ALTER TABLE Kyll_fluss_100 ADD COLUMN DGM_n
double precision
ERROR: Cannot continue (problem adding column).
ERROR: Cannot continue (problem to add column).
> - which GRASS version
I'm running grass 6.2.1
> - which operating system
On an ubuntu edgy with gnome
Another thing I noticed is that it does not work if vector file and
table have different names (I dind not forget to connect the tables;-))
Greetings from the fog here
And thanks
Manuel
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
