[GRASS-user] v.in.ogr: shape files import trouble
Moritz Lennert mlennert at club.worldonline.be
Mon Mar 12 08:04:52 EDT 2007
On 12/03/07 11:54, Raffaele Morelli wrote:
>     how does it look if you skip cleaning the data?
> Same problem -c doesn't affect resulting vector.
>     topology is not guaranteed then, but if the data is only for looking at
>     it might be ok.
>     v.in.ogr -c
> tried with min_area and snap option, also imported without cleaning and
> later applying v.clean with several tools/paramenter settings.
> I faced this problem some time ago / /when using v.patch (Maciej should
> remember about that) from those same files.
> I guessed it was an overlapping shapes problem or, as Pierluigi
> suggests, an incorrect topology issue.
> But, how can I get data displayed like in QGis? or can I at all?
Try v.external.
Moritz
