[GRASS-user] Compiling grass 6.2.1: i.class error
Sean Fulton seanasy at gmail.com
Tue Mar 13 10:48:01 EDT 2007
Thanks for the reply. I am trying to compile it for MacPorts (formerly
known as DarwinPorts). No GRASS libs on my system, I'll keep plugging
away.
	Sean
On 2007-03-09 12:24:08 -0500, William Kyngesburye <woklist at kyngchaos.com> said:
> Sean, if you just need to *use* GRASS and want to stick with 6.2.1,
> have you tried my binary?
> I can't think of what the problem might be - obviously I built it
> successfully, and didn't have this problem.
> If something went wrong with the imagery lib compilation, try looking
> further up in the build output where the imagery lib is built - maybe
> there was an error or warning up there?
> I see you use /opt/local for extra libraries - Darwinports?  Are  there
> any GRASS libraries in there for some reason?
> On Mar 9, 2007, at 10:46 AM, Sean Fulton wrote:
>> On 2007-03-05 20:45:41 -0500, Glynn Clements  <glynn at gclements.plus.com> said:
>>> Sean Fulton wrote:
>>>> I'm trying to compile 6.2.1 on Mac OS X 10.4.8.  I get an undefined
>>>> symbol (_I_vask_subgroup_old) error compliling i.class.
>>>> Can anyone point me in the right direction for resolving this?  Output
>>>> is below.
>>> How/where did you get the source code? The file containing that
>>> function (lib/imagery/vask_group.c) has been removed from the CVS
>>> trunk, but is still present in the 6.2 branch.
>>> Also, if you have a 6.3 version installed such that the linker will
>>> find its libraries, that could potentially cause this problem.
>> So, are you recommending using the CVS version? (I'd rather not)
>> Is there any clue to what the problem is?
>> Thanks,
>> 	Sean
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed  robot?
> [Marvin]  You think you have problems?  What are you supposed to do  if
> you ARE a maniacally depressed robot?  No, don't try and answer,  I'm
> 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
