[GRASS-user] pan/zoom while digitizing
Wed Mar 14 07:08:50 EDT 2007
Ricardo Oliveira wrote:
> While i am using r.digit i need to zoom/pan but i haven`t found a
> way to do so...the window size is locked?
You can't force a running program to change the region it uses
internally. So you could change the region stored in the WIND file
using g.region, but that won't affect r.digit.
