[GRASS-user] Alaska shapefile crosses 180th parallel
Gary Sherman sherman at mrcc.com
Thu Mar 15 21:15:31 EDT 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
If you are only interested in Alaska an perhaps part of Canada and
Russia, you could always project the data to Alaska Albers:
- -PROJ_INFO-------------------------------------------------
name       : Albers Equal Area
proj       : aea
datum      : nad83
a          : 6378206.4
es         : 0.006768657997291279
lat_1      : 55
lat_2      : 65
lat_0      : 50
lon_0      : -154
x_0        : 0
y_0        : 0
no_defs    : defined
- -PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1
On Mar 15, 2007, at 1:43 PM, Brent Wood wrote:
> Paul Van Deusen wrote:
> Welcome to my world :-)
> Working in the maritime area around New Zealand, 180 is an issue I
> deal with regularly :-(
> I suggest you add 360 to every longitude < 0. This moves the break
> to zero degrees instead of 180.
> You can also use a variety of local projections to avoid the issue.
> There is a parameter in the CVS version of proj4 to set the central
> meridian, defaults to zero, but a reprojection to WGS84 (EPSG:4326)
> with explicit parameters, & the central meridian of 18- works well....
> Brent Wood
>> I'm trying to read in the state boundary shapefile from http://
>> nationalatlas.gov.  However, the Aleutian Islands
>> cross the 180th parrallel, so longitude goes from +180 to -180 at
>> that point.  I end up with the end of the
>> Aleutian Islands getting disconnected.  What is the solution?  I
>> used v.in.ogr and set up a location using the information that came
>> with the shapefile.  See spatial information below..
>> Spatial_Reference_Information:
>>  Horizontal_Coordinate_System_Definition:
>>    Geographic:
>>      Latitude_Resolution: 0.000278
>>      Longitude_Resolution: 0.000278
>>      Geographic_Coordinate_Units: Decimal degrees
>>    Geodetic_Model:
>>      Horizontal_Datum_Name: North American Datum of 1983
>>      Ellipsoid_Name: GRS1980
>>      Semi-major_Axis: 6378137
>>      Denominator_of_Flattening_Ratio: 298.257222
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
- -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
"We work virtually everywhere"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (Darwin)
iD8DBQFF+e+01zKuzV6goTgRAjjrAJ9Fp1YYqi03Ad44d2bKgMa39HTn2ACgpFPX
TuQxiQQJ+vIxZDwXwaNH/2s=
=qi5X
-----END PGP SIGNATURE-----
