[GRASS-user] re : i.his.rgb issue
Massimo Di Stefano massimodisasha at yahoo.it
Fri Mar 16 08:08:18 EDT 2007
Issue fixed in the cvs :-)
Il giorno 16/mar/07, alle ore 12:26, Massimo Di Stefano ha scritto:
> hi
> i've an error using the last cvs version on the command
>  "i.his.rgb"
> i tried the same command using grass6.2.1 and an old (3 week) 6.3
> cvs without problem.
> but using the last cvs (downloaded yestrday)
> it give me :
>  "unable to find imput cell map <red>"
> but the "red" map is an output ... see the screenshot : on the
> right the 6.3cvs, on the left 6.2 :
> http://img206.imageshack.us/img206/9130/immagine14ib2.png
> is this a common problem ... or something is wrong in my last build ?
> thanks,
> Massimo
