[GRASS-user] i.his.rgb issue
Fri Mar 16 08:44:03 EDT 2007
Massimo Di Stefano wrote:
> i've an error using the last cvs version on the command
>   "i.his.rgb"
> i tried the same command using grass6.2.1 and an old (3 week) 6.3 cvs
> without problem.
> but using the last cvs (downloaded yestrday)
> it give me :
>   "unable to find imput cell map <red>"
> but the "red" map is an output ... see the screenshot : on the right
> the 6.3cvs, on the left 6.2 :
> http://img206.imageshack.us/img206/9130/immagine14ib2.png
> is this a common problem ... or something is wrong in my last build ?
Both. This is a common symptom of trying to perform a partial build
(i.e. without running "make clean") after updating from CVS.
Always run "make clean" before updating from CVS.
