[GRASS-user] i.his.rgb issue
Brad Douglas rez at touchofmadness.com
Fri Mar 16 20:18:08 EDT 2007
On Fri, 2007-03-16 at 12:44 +0000, Glynn Clements wrote:
> Massimo Di Stefano wrote:
> > i've an error using the last cvs version on the command
> >   "i.his.rgb"
> > i tried the same command using grass6.2.1 and an old (3 week) 6.3 cvs
> > without problem.
> > but using the last cvs (downloaded yestrday)
> > it give me :
> >   "unable to find imput cell map <red>"
> > but the "red" map is an output ... see the screenshot : on the right
> > the 6.3cvs, on the left 6.2 :
> > http://img206.imageshack.us/img206/9130/immagine14ib2.png
> > is this a common problem ... or something is wrong in my last build ?
> Both. This is a common symptom of trying to perform a partial build
> (i.e. without running "make clean") after updating from CVS.
> Always run "make clean" before updating from CVS.
It was actually a minor mistake I made.  I talked to him last night on
IRC (#grass) and promptly fixed it in CVS.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
