[GRASS-user] Encountering an error importing shapefiles with v.in.ogr
Thomas Adams Thomas.Adams at noaa.gov
Mon Mar 19 10:35:41 EDT 2007
List:
I am using GRASS 6.2.1 and I (sometimes) encounter an error importing a
shapefile with v.in.ogr. The vector boundaries import fine, but gis.m
crashes. I can re-start gis.m and load the vector file that I just
*attempted* to import and it displays fine. However, I get a warning:
Cannot display areas, topology not available.
I am virtually certain that I was able to successfully import this and
other shapefiles in previous versions of GRASS (GRASS 4.x & GRASS 5.x).
The shapefiles files include the *.dbf, *.shp, and *.shx files, which I
think, should be enough. If I import shapefiles from the US National
Atlas (created by the USGS), I have no problems. It seems that with all
shapefiles generated by my office using ArcGIS 9.0, I have this problem.
Does anyone have suggestions as to what could be going on? I would like
to use v.rast.stats using the imported vector files, but given the
error/warning, v.rast.stats will not work.
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
