[GRASS-user] [Fwd: v.out.ogr - Writing to Shapefile]
Andrew Schroeder - Charone Concepts Ltd. Andrew_Schroeder at charoneconcepts.com
Tue Mar 20 15:28:05 EDT 2007
Cancel that, solved it - Cygwin folder....
Andrew Schroeder - Charone Concepts Ltd. wrote:
> -------- Original Message --------
> Subject: 	v.out.ogr - Writing to Shapefile
> Date: 	Tue, 20 Mar 2007 11:20:14 -0700
> From: 	Andrew Schroeder - Charone Concepts Ltd.
> <Andrew_Schroeder at charoneconcepts.com>
> Organization: 	Charone Concepts Ltd.
> To: 	Grassuser <grassuser-bounces at grass.itc.it>
> I'm trying to export areas to a shapefile with no luck.  The areas were
> created using v.voronoi, and I can view them just fine in GRASS, but
> when I attempt the export it doesn't seem to be actually creating any
> files.  It does say 407 features written.  I'm using GRASS 6.2 on windows.
> When the "dsn" specifies a folder that doesn't exist does it go on to
> create the folder?  In this case the folder "export" doesn't exist.  I'm
> guessing that it doesn't create the folder because it'd not there once
> the export is complete.  Maybe my syntax is completely wrong, but I just
> can't get this to work (or find the file if it is working...)
> The command I'm running:
> v.out.ogr input=Samples_Vor type=area dsn=/export olayer=samples_vor_exp
> layer=1 format=ESRI_Shapefile
> Any help you guys can offer would be GREATLY appreciated!
> Thanks,
> Andrew Schroeder
